87 300D heating system problem
Old Apr 18, 2007 | 10:31 PM
JamesWendell's Avatar
Default 87 300D heating system problem
I have had the HVAC dash control replaced last year. Over the winter I ended up with no heat. There was a clicking noise from a valve (?) near the battery. I disconnected the cable at the top and I have plenty of heat. (Too much on a less than cold day.) What is this unit and how does it affect the HVAC system? Is there a good chance that if I replace it my problem will be solved?
[IMG]local://upfiles/3338/527729CBDA1D40D3963A990499823A1A.jpg[/IMG]
Old Jan 5, 2009 | 06:42 PM
jimishadow's Avatar
Default RE: 87 300D heating system problem
monovalve
Old Jan 7, 2009 | 07:03 PM
boblo_home's Avatar
The Automatic Control System HVAC is faulty by the look of it. I doubt it is the monovalve. The valve is controlled by 12V. Fully open when NO voltage or disconnected, fully close with 12 volt. Anything voltage in between is to control the opening gap for the hot water to flow through.
If you have heat when cable is disconnected then it means it opens OK. The cable is stuck at 12v even when heat is called for. Put the car on full heat, remove the connector and measure the cable connector with a voltmeter. Wait a while for the unit to settle. If it reads 12v ALL the time then the HVAC is faulty. Also your axuiliary pump is OK as you have heat when you removed the connector.
Good luck.
Durin S Day
Nov 17, 2012 01:30 PM
Bhofferb
Sep 18, 2007 12:17 AM
mal
Sep 8, 2005 05:47 AM
shaynecrowe
Oct 24, 2004 05:11 AM
TimK
Feb 9, 2004 01:44 AM
