87 300 sdl injector line still leaking
Old Nov 9, 2005 | 10:23 AM
aquaman's Avatar
Default 87 300 sdl injector line still leaking
I just replaced my #4 injector line with a used line. Initially it
was leaking from the injector. Replacement fixes the leak there
but is now leaking at the IP. The compression nut tightens down but
the line still feels loose at the IP and there is still fuel leaking.
Is there a way to put a washer inside the nut to make the nut
compress down more on the flange?
Any thought would be greatly appreciated.
M.
Old Nov 9, 2005 | 08:42 PM
Benzbob's Avatar
Default RE: 87 300 sdl injector line still leaking
I think you will find that there is a hair-line crack at the base of the injection tube. It is a fairly common place where they crack. It is due to vibration and fatigue. Replace the tube and make sure that all the rubber mounts where the tubes rest are secure. I used rubber pads I cut from an old inner tube and tied each injection tube secure with cable ties. Doing this will dampen vibration in the injection tubes reducing, or eliminating, premature fatigue and cracking...Good luck.
Old Nov 11, 2005 | 06:32 PM
aquaman's Avatar
You nailed it BenzBob.....
There is a small crack on top of the flange.[:@]
Oh, I guess I will have to eat the cost of a new one.
M
Old Nov 11, 2005 | 08:01 PM
Benzbob's Avatar
Aquaman, I saved all the injector lines from my old 603 and found that I could bend into shape some of the lines to accommodate other than the injector it was pre-bent to fit to!
Don't know if you have spares, but it may be worth it when you discover what they get for new ones!
Just secure them really well, otherwise you'll be replacing more!
spicybabes
Apr 8, 2009 11:23 PM
bowpro
Apr 10, 2008 01:39 AM
bowpro
Apr 8, 2008 07:44 PM
gugufut3
Jul 3, 2007 11:32 AM
aquaman
Nov 1, 2005 10:22 AM
