'83 300SD rides again
Fixed several issues on the car, but have numerous to go, but she's very drivable. I put in an air filter while servicing many items. The pan in which the filter sits was coated in oil and even had a very small pool of it in one spot. Never seen anything like that. I am assuming that it was from the PCV valve which is connected to the rocker cover. The PCV valve is also seeping a little where it connects to the rocker cover. I also, on occasion, get a chattering when I turn the switch on. Not as its starting or when running, just as I turn the switch. It's coming from the box (can't recall what it is) right next to the radiator on the driver side of the engine. It connects I think to engine and injection pump. What gives? Any help would be much appreciated.
