81 300SD Diesel Tach works sometimes
Old Jul 18, 2006 | 08:42 PM
danpayton's Avatar
Default 81 300SD Diesel Tach works sometimes
The tachometer on my 81 300 SD turbo diesel only works once in a while - I am not fimiliar with how mercedes senses engine RPM on their Diesels.... Is there a sensor on on the crank or something?
are their any cronic problems i should know about with the tach on this model?
Any thoughts greatly appreciated
thanks!
-Dan
Old Jul 19, 2006 | 10:27 AM
timberfield's Avatar
Default RE: 81 300SD Diesel Tach works sometimes
There is a pickup behind the pully on the front of the crank. Check the wire to it. Also, the tach transmitter is a gizmo on the driverside inner fender (engine compartment) it's round, about 2" diameter, it plugs into a socket. They go bad once in awhile, but try cleaning the contacts. Also make sure the connection is good on the back of the instrument cluster. On my 85, there is a small wire connected to the positive side of the battery that I left off by accident once. It caused the tach and A/C not to work....good luck!
Mrman
May 10, 2015 08:16 PM
walpoleauto
Jan 21, 2011 08:17 PM
widmer
Oct 19, 2007 03:14 PM
bookerzisme
Jan 12, 2006 08:43 PM
nineknot
Apr 19, 2004 04:17 PM
