81 300d no power
Old May 13, 2011 | 12:50 AM
anths's Avatar
Default 81 300d no power
Hello all, I have an australian 300d that has engine problem i have inherited it has no power,starts and runs, idle is a little shaky but smooths out when you adjust the throttle.
On light throttle it's sluggish and has no power, when you pull out into traffic you need a large gap to allow it to slowly build up speed, which it does but in it's own time
It really make's little difference where you hold you foot she lack's torque and get up and go!
Things i have noticed is a small leak of diesel around the 5th injector and smoky exhaust that is very slight on idle but not evident when driving and not black.
Any suggestions or advice would be greatly appreciated
Cheers Anthony
Old May 13, 2011 | 09:00 AM
oldrebuiltdodge's Avatar
I am going through the same thing, found that the catalytic converter was plugged. I'm still not real happy with it, but it does move out much better now that the converter is un-plugged. You might also try changing the fuel filters, and clean or change the strainer in the tank. Pay close attention to the o-rings on the top bolt of the secondary filter, they sometimes leak, if it pulls air through there it will cause the troubles you describe.
Old May 14, 2011 | 09:29 PM
anths's Avatar
Thankyou,
Our model Aussie 300d dosen't have a cat convertor but the strainer is something i haven't looked at yet so will do.
filters were changed not too long ago and the problem hasn't changed,Im wondering if the injector's are the issue as i steam cleaned it today and have noticed there all weeping but not around any of the fittings or hoses!
Cheers Anthony
Old May 19, 2011 | 01:50 AM
anths's Avatar
Hi all, I think i have found the problem replaced the injectors engine is performing better, but what made a huge difference was i serviced the auto trans and adjusted the modulator completely different car not 100% but a lot better.
would like to thank all with there suggestions
cheers anthony
Brian2009
Jan 8, 2009 08:53 PM
saint
Nov 13, 2008 06:49 AM
saint
Nov 9, 2008 09:24 PM
vlindell
Oct 28, 2008 08:33 PM
wesweber
Nov 19, 2007 08:23 AM
