'81 300 D won't start
Old Jan 8, 2009 | 01:55 PM
  #11
djgonzo's Avatar
Default RE: '81 300 D won't start
ORIGINAL: cycleboy
Because your neutral safety switch is faulty/out of adjustment.
How do I repair this?
Old Jan 8, 2009 | 03:32 PM
  #12
cycleboy's Avatar
google the subject within the diesel discussions and you'll find it. it's reasonably common.
Old Jan 8, 2009 | 08:09 PM
  #13
djgonzo's Avatar
Anything else I should replace at the same time as the Neutral Safety Switch?
Old Jan 8, 2009 | 08:44 PM
  #14
cycleboy's Avatar
Nothing I can think of offhand, other than doing a complete tune-up.
Old Jan 18, 2009 | 09:43 AM
  #15
djgonzo's Avatar
Default Problem fixed...
Replaced the glow plugs and adjusted the valves....problem solved. Thanks for the help!
Old Jul 16, 2011 | 12:57 AM
  #16
geoffscott's Avatar
When the engine is cold or only slightly warm the glow plugs need to cycle on to preheat the pre- chamber where the fuel is injected. If the glow plug light does not come on, then there is a fault you will have to locate. I am not sure if the transmission neutral switch is part of this circuit, but as you have described, it seems like it is. The switch is cheep in price and easy to replace on the transmission. Could also be the linkage needs adjustment, but I would think probably not.
If all checks out with the switch, you need to check the glow plug relay and wiring and ALL the glow plugs.
Mercedessource have a manual kit if all else fails. If I remember right, it sells for about 100 USD
But as the glow plugs cycle on and the engine starts well in neutral, I would think the neutral switch on the side of the transmission is faulty.
Originally Posted by djgonzo
So I spoke with the previous owner and he suggested that I put the car in neutral, and then turn the ignition on. I did so and the glow plug light came on then went off, put the car in park and it fired right up! It seems like the glow plug light won't come on while the car is in park but will when shifted to neutral. I repeated theses steps a few times and the car fires up immediately. BTW, it is cold outside.
The previous owner remembers this happening on a 300d he had a few years back but says it hasn't happened on this car before.
I test drove the car twice, both times in cold weather and didn't have to do this before nor did I have to do this Saturday when I bought the car and drove it all over town turning it on then off 6-7 times while in park.
Any ideas as to why the glow plugs go on/off in neutral bu not in park?
Goldengirl1
Nov 8, 2012 07:28 PM
doobs
Dec 21, 2008 09:58 AM
penja
Dec 27, 2007 03:33 PM
gugufut3
Jul 3, 2007 11:32 AM
panda12c
Apr 29, 2005 11:02 AM
