79' 300TD Brake Booster Problems?
Old Jun 27, 2008 | 12:07 PM
pilotis1's Avatar
Default 79' 300TD Brake Booster Problems?
Hello,
My wagon is having problems braking. It does fine when i first start to brake, but i hear a hissing sound under the dash as if it's losing vacuum pressure. then the "power" goes out of the braking and i have to really press down on the brake pedal to get it to stop. i've rebuilt the vacuum pump, checked all the vacuum lines and believe i've traced the leak to the power booster. what do you guys think? is it just a simple replacement of the brake booster? anyone have the same experience as i have?
Old Jul 3, 2008 | 04:39 PM
idecelr8's Avatar
Default RE: 79' 300TD Brake Booster Problems?
The power brake booster is just that: a booster. It sounds like there is a leak in the diaphragm and the only cure is to replace it.
I would look in a junk yard for one of these. There appear to be lots of these old 123 cars around and the booster are all the same. They can be a sort of a pain to change but they do not take any special tools to swap out.
You will still have manual brakes until this is repaired. Just remember to start stopping a long time before you used too.
Sam
Old Apr 21, 2013 | 09:09 PM
illinois240D's Avatar
Any tips on removing the brake booster? Do I have to pull the speedometer/ odometer to get to the bolts that hold the booster to the firewall?
augF185
Nov 21, 2008 01:07 PM
wtrmn18
Apr 1, 2008 08:28 PM
joe4324
Nov 9, 2007 07:55 AM
donhall
Oct 27, 2007 11:29 PM
blankenship
Apr 16, 2005 01:23 AM
