74 240d oil cooler
Old Apr 15, 2009 | 09:42 PM
skippy's Avatar
Smile 74 240d oil cooler
my oil cooler leaks. what is recomended? trying to keep the original setup or can i put a aftermarket cooler on or can i just disconect it and not have a cooler i know i have to leave to orginal cooler in to hold the radiator in
Old Apr 16, 2009 | 07:58 AM
cycleboy's Avatar
The cooler leaks or the lines leak? Replace what leaks. You really shouldn't do without the cooler.
Old Apr 22, 2009 | 12:58 AM
skippy's Avatar
pretty positive it's the cooler i'll check to make sure but are aftermarket coolers ok to use or should i keep it orginal and thanks for replying
Old Apr 22, 2009 | 09:22 AM
cycleboy's Avatar
Usually the easiest thing to do is go with an oem part. You know it will bolt right in without any hassle. If you don't want to buy a new one, you should be able to get a good used one fairly inexpensively.
dpm052
Oct 11, 2008 11:21 AM
otm646
Feb 9, 2007 03:12 AM
300tdgen
Oct 11, 2005 11:50 PM
benztiller
Sep 18, 2005 06:24 AM
300tdgen
Sep 8, 2005 01:15 AM
