350SDL Injection Pump Service
Old Feb 18, 2008 | 04:02 PM
paul060266's Avatar
Default 350SDL Injection Pump Service
For my 91 350SDL, I would like to remove the pump and have it serviced at a Bosch facility. I am having trouble finding any manuals or references on how to remove and then reinstall and time properly...is it the drip method as is done on the 5-cylinders? Any replies would be appreciated.
Thanks,
Paul.
Old Feb 19, 2008 | 06:25 AM
paul060266's Avatar
Default RE: 350SDL Injection Pump Service
Thank you for the link and commentary.
Not leaking oil and not using oil, 250k miles, all injectors rebuilt and pop tested, system purged, no smoke but a little stinkier than usual. I hear a plop-plop-plop on idle so I am thinking that not enough fuel is being metered to one cylinder. Any suggestions appreciated.
Thanks,
Paul.
Old Feb 19, 2008 | 09:47 AM
paul060266's Avatar
The intention was to have the pump inspected, not necessarily rebuild it.
The car has new engine mounts, new belt tensioner and shock.
Will check around the exhaust manifold, turbo, and intake as you have suggested this weekend...thanks.
Old Mar 14, 2008 | 07:25 AM
paul060266's Avatar
I found that the cross-over pipe had a bad gasket.After replacing the gasketitimproved the situation but it still plop-plop-plops out the exhaust...any other thoughts would be appreciated.
tygman
May 20, 2008 06:15 PM
PerkHouse
Aug 7, 2006 07:02 PM
varval
Apr 10, 2006 07:06 PM
varval
Apr 6, 2006 03:44 PM
Bigeasyherb
Jan 28, 2005 12:57 AM
