300d won't shut off
Old Dec 7, 2008 | 06:03 PM
scoobysteven's Avatar
Default 300d won't shut off
I was given a free car, 1985 300D. Car runs strong, but won't shut off. Even when I press the red "Stop" lever, it still wants to run. I know the car has vacuum issues, and I know about the fuel injection shutoff solenoid, but could it need another vacuum valve. I hear there are two other vacuum valves that might be bad. Any suggestions? Also, the transmission shift hard, chirps going into secind gear if you hold down the throttle. Any help is welcomed
Old Dec 7, 2008 | 08:28 PM
84 300d diesel's Avatar
Default RE: 300d won't shut off
so... how are you turning it off
Old Dec 14, 2008 | 02:13 PM
dabrown's Avatar
Hey, any luck with this? Mine just started having the same problem yesterday after I tried to fix some of my vacuum hoses which had gotten unplugged. If you think your problem is vacuum related, try this site: http://dieselgiant.com/mercedesvacuu...leshooting.htm
Let me know what the outcome is.
Old Dec 15, 2008 | 08:04 PM
jimishadow's Avatar
get a vacuum gauge and chec vacuum pump.if the pump is weak or not working rebuild it.4 of my cars needed vac pump rebuild to make all vac systems work.
Squire
Aug 27, 2010 08:27 AM
moondoggy
May 4, 2008 07:20 AM
gm55
Apr 28, 2007 10:53 PM
dsalustri
Nov 2, 2006 04:02 PM
amore76
Oct 25, 2006 01:36 AM
