300D water leak
Old Jan 13, 2008 | 03:25 PM
HG's Avatar
HG
Default 300D water leak
Hi All,
I've got a 300D with water leak. We pulled the water pump and water pump housing but there are no clear leak paths apparent. There appear to be two possibilities:
(1) where the water pump housing mates to the block. We did not find any gasket on the housing or water jacket port.
(2) a single bolt hole in the block about an inch below the water pump housing. The bolt hole is threaded with the same thread size as the water pump housing but there was no bolt present. No indication as to what -- if anything -- was bolted up to that hole.
Any thoughts or suggestions would be greatly appreciated.....
Hal
Old Jan 19, 2008 | 12:23 AM
ajrn's Avatar
Default RE: 300D water leak
Yikes..
Can you shoot us a picture with the water pump on/off or something??
Even if none of us can tell you what the function is-- maybe one of us can compare, to show you what was SUPPOSED to be there..
AJ RN
Durin S Day
Sep 2, 2013 02:39 PM
hawke
Jul 20, 2007 07:44 AM
gte811f
Aug 9, 2005 12:50 AM
cleatus
Jun 24, 2005 01:18 AM
ska
Jun 11, 2005 11:15 PM
