300d steering vibration
Old 04-05-2008 | 10:56 PM
dakota3c06's Avatar
Default 300d steering vibration
Quick help. My 85 300d is vibrating badly between 60-70mph. It gets really noticable when turning left or right at that speed. Am I looking at tie rods?
85 300d 4dr 181k
Old 04-09-2008 | 09:53 PM
81 300 CD's Avatar
Default RE: 300d steering vibration
raise each front wheel one at a time grab tire at 3 and 9 o'clock and wiggle back and forth any play should be tie rod 2 and 8 o'clock and4 and 10 o'clock can check wheel bearings.remove inspect adjust if play is found. ball joints are a little more involved and better done on a lift. there is also pitman arm idler arm and steering stabilizers on some models. if you have a good idea with what you know you'l probably figure it out otherwise see a reputable shop.
ioang26
06-30-2007 04:48 AM
Sharp
11-17-2006 08:56 PM
ziggytwizzer
05-09-2006 08:56 AM
manaiauds
01-02-2006 09:00 PM
Quick Reply: 300d steering vibration
