1999 E300 - deep knock above idle
Old Jan 12, 2008 | 01:00 AM
Lemosx4's Avatar
Default 1999 E300 - deep knock above idle
I'm a first time poster. I haven't had a chance to review all of the postings in this forum, so if this issue has already been addressed, I apologize.
My 1999 E300 has been a very smooth, quiet, powerful turbodiesel since I purchased it about 15k miles ago. Itnow has 123k, and has always been very well maintained.
However, today it began to make this horrible knock at any RPM above idle. It now idles a little rough, but not terrible. Above idle, it sounds like a rod knock, but I believe it's unlikely to actually be a rod. I am new to diesels, but am pretty mechanical. I don't mind working on it, but I'm reluctant to just start tearing it apart and replacing stuff. Any ideas what might be causing this knock and rough idle? Both occured today.
Any assistance is greatly appreciated.
Thanks,
Ed
Old Jan 12, 2008 | 08:24 AM
pimpernell's Avatar
Default RE: 1999 E300 - deep knock above idle
96 E300d here:
Just offering some suggestions...first, I would take a look at the oil dipstick to make sure that the oil is at the proper level. From what you describe, it sounds to me like one of you injectors is clogged, and that particular cylender is not firing. The fact that it idles rough, and "knocks" at higher rpms would suggest that this might be the case. These engines have a tough lower end, and usually if a rod bearing is on the way out, it will do so gradually. The "knock" would have a tendency to increase in sound level gradually over time. From what you describe, this has just suddenly appeared and that would lead me to believe that an injuctor may be fouled. I am including a link to another web site where you can post and get a lot more info.........Good luck
http://www.mercedesshop.com/shopforum/index.php
Old Jan 12, 2008 | 10:41 AM
Lemosx4's Avatar
Thanks much for the input. I believe the changing of the injectors is something I should be able to handle. Now, assuming it's an injector clogged or partially,or failed - is there diesel purge or some other injector cleaner that I can use to clear it out, or is it just too late now?
Also, how long do these injectors typically last? I wouldn't think 123k miles would kill an injector, but maybe it does.
Could anyone provide a quick step by step on changing the injectors on this car?
Thanks, Ed
Old Jan 13, 2008 | 12:30 PM
pimpernell's Avatar
check out this link, the problem is almost identical to yours, and they give some ways of checking it out. Good luck
http://www.mercedesshop.com/shopforu...t=bad+injector
gamefacenyc
Oct 10, 2006 02:35 PM
e55style
Sep 15, 2006 01:33 AM
Mercv8
Aug 29, 2006 11:57 AM
dekidex
May 16, 2006 07:09 AM
