1991 350SD Shock tensioner
Old 12-16-2011 | 09:33 PM
pricej01's Avatar
Default 1991 350SD Shock tensioner
The shock tensioner on the engine drive belt assembly is going bad - this is the 3rd one I have had to replace in 240K miles. I was hoping to complete this task myself - does anyone know how to remove the bottom mounting bolt? When I back it out with a wrench, it strikes the water pump pulley before coming completely out. Thanks for any support you may have to offer.
Also, does anyone have a recommendation for a mercedes diesel mechanic in the Raleigh, NC area? I am having trouble finding any expertise for a 20 year old car - especially the older diesels.
Old 12-18-2011 | 10:29 PM
oldrebuiltdodge's Avatar
You will most likely have to remove the water pump pulley, or at least loosen it depending on how long the bolt is.
mercedesdieselpetr
10-06-2012 09:49 PM
sbakshi1
10-03-2007 06:46 PM
thedonofdiesel
03-19-2007 11:03 AM
CmyBenz
07-31-2005 04:23 AM
zanybrainy
05-15-2005 01:50 AM
