1974 240D Shifting Problem
Old 03-01-2009 | 12:17 AM
TheLinkster's Avatar
Default 1974 240D Shifting Problem
I'm looking at buying a 1974 240D that has a supposed Transmission Problem.
Here is a quote from the owner.
" runs great but sometimes cant shift into gear was told its the shift linkage or trans modulator trans fluid looks good"
Do I go investigate or run away? (The car is pretty dang cheap.)
Sounds like it could possibly be a broken Kickdown switch?
I'm 17 so I dont have much experience wrenching on cars but I have been obsessed with cars since I was 7, so I have a pretty good knowledge of whats what.
Old 03-05-2009 | 10:38 AM
barrylndn's Avatar
Default My experience
I've also got a 240d that I purchased recently, and it wouldn't go in to gear unless I pulled the shift lever down far below the gear I wanted it to go in. In a discussion on mercedesforum, it was mentioned that I check the shifter bushings. There are several - some very high in the linkage, and two lower ones. I had the lower ones replaced, and it has taken care of the problem - I also didn't have the park break before, and now I do. It was just too sloppy from the shifter down. Not that it couldn't be something else, but that took care of it for me. It's still a little sloppy - the higher up ones are also very worn, but now it drives when I put it in gear :-). Have someone who knows about old mercedes check it out.
bradivy9
04-26-2009 07:12 AM
buzz_42
04-22-2009 10:24 AM
dvdiesel
03-23-2009 08:00 AM
barrylndn
02-14-2009 07:57 PM
ehrichweiss
12-17-2007 06:14 PM
