190d losing power
Old Nov 30, 2006 | 04:30 PM
AMGMercedes's Avatar
Default 190d losing power
So today I had a job interview for Banker's Life in Hagers Town. When I was on I-70, I noticed that my car jerked forward, then slowed down...then repeated. It happened exactly like the time when I almost ran out of fuel a few months ago...but right now I've got half a tank left. When it was losing power today, it was at high speeds about 60-70mph, more noticable uphill. What could be the issue?
>Also, a month ago I stopped at my mechanic to see if he could find where I was leaking coolant (that problem is fixed; new thermostat) but they did notice that I was leaking fuel near the engine. Dunno if that has anything to do with it...
Old Nov 30, 2006 | 05:03 PM
mbz300sdl's Avatar
Default RE: 190d losing power
Well have u replaced ur fuel filters and since the car has low miles you might want to replace all the fuel lines. Also have u run diesel purge or another diesel cleaner in it?
Old Nov 30, 2006 | 05:05 PM
gododiroma's Avatar
SImply change your spark plugs
Old Nov 30, 2006 | 05:07 PM
mbz300sdl's Avatar
[sm=lame.gif]Diesels dont have spark plugs.
Old Nov 30, 2006 | 05:14 PM
Owned That was too funny. I should have mentioned diesel though.
No I haven't ran a purge yet. How would I change fuel filters, like where are they located and how many of them are there?
Old Nov 30, 2006 | 05:49 PM
Charles Munn's Avatar
ORIGINAL: mbz300sdl
Good advice! I'd definitely put my money on a clogged fuel filter.
Old Nov 30, 2006 | 06:12 PM
mbz300sdl's Avatar
As sleepwalker he can tell u i have no experince with 190d or 190e. You did not need to say diesel the "d" should have indicated it to anyone worthy of responding
Old Nov 30, 2006 | 06:26 PM
kokigami's Avatar
another thought, if you are leaking fuel, you could be sucking air.
Suziguns
Feb 3, 2010 05:11 AM
BOB CHODA
May 25, 2008 11:53 AM
Its_Puddin!
Nov 8, 2007 07:02 AM
Mawbs
Aug 27, 2006 09:04 AM
npk
Jun 19, 2005 12:56 PM
