Detailing Discuss detailing your ride inside and out here.
Removing sun visor stickers
Old Feb 11, 2007 | 07:13 PM
Barry Hanna's Avatar
Default Removing sun visor stickers
Just gently heat them and pull off? Can I use the 3M solvent for any residual stickum?
Old Sep 11, 2010 | 08:54 AM
ripa's Avatar
I had the same question. Did you get them off?
Old Sep 30, 2010 | 09:22 PM
ncmudbug's Avatar
I recently took off the ones that show (I didn't take the ones that don't show when the visor is up) from my 2005 C230K. They just peeled off. I didn't anything special except try to be careful so I didn't end up with half a sticker on my visor!
YMMV
Jim
Old Jun 18, 2014 | 08:26 PM
mercful's Avatar
Wd40 can remove it and use a plastic scraper and blade to scrape it off.
Old Jan 30, 2018 | 04:58 PM
RSAUTOSPA's Avatar
you can use googone to remove the sticky glue.
Old Mar 3, 2019 | 01:51 PM
marnus.labuschagne's Avatar
I used to work in a sign shop and had to eliminate this stuff daily and used a heat gun to soften the glue and then scrape it off with an old credit card. Any one of you can use a single edged blade to scrape on the glass. We tried not to use solvents on them, it causes more troubles than it helped.
brookings
Mar 20, 2015 02:21 AM
Charlie C
Aug 25, 2010 12:39 PM
ras716
Jul 12, 2008 07:17 AM
tancalvo
Aug 8, 2006 04:33 AM
aharley1
Jul 28, 2006 10:37 PM
