Audio/Visual Electronics Wired up? Got a cool radio? Everyone's got some sort of electrical modification. let's hear about it.
Sirius Radio Problem
Old Feb 25, 2010 | 04:51 PM
159515100's Avatar
Default Sirius Radio Problem
My Sirius radio has acted quite strange the last few weeks and ideally someone will have an idea of what might be wrong with it. It constantly is searching for signal and then one day, no problem it works fine only to have the same problem the next day. All of the other functions of the audio system work fine. Any ideas!
Old Feb 26, 2010 | 10:38 PM
2150john's Avatar
I have a similar problem, except that mine will now not find a satellite at all. It says acquiring signal on the Head Unit and the dash display says NO SAT. Some have suggested a problem with the antenna connection.
I would be curious to know if you find a solution to your problem.
Old Mar 1, 2010 | 03:19 PM
159515100's Avatar
Default Problem solution
I don't know if I am lucky or just solved the problem temporarily but I followed the wire from the antenna to where it was connected to the audio system and simply disconnected it from there (it was just a normal connector which was taped around the connection) and carefully reconnected it followed by new tape. It now seems to work fine, we will see. If I was really smart and lucky I would have just opened up the slot on the left side of the trunk and could have solved the problem without having to re-run the wires back up to the roof of the car. Oh well, at least if I have to replace the antenna ultimately I can see that it will not be that difficult!
varlerw2
May 30, 2006 08:59 PM
filip75
Jan 23, 2006 03:14 AM
CDDANFORD
Aug 3, 2005 01:47 AM
shauntx
Jun 29, 2005 07:10 PM
rpaul
Feb 20, 2005 08:45 PM
