84 190D Front Speaker Removal?
I just got some new Infinity speakers to replace the Altec's that were previously put in the dash, but I can't figure out how to do it without disassembling the dash. Anyone know how? Thanks!
Andrew
'84 190D
'67 250S
'69 220D
'95 C280
Andrew
'84 190D
'67 250S
'69 220D
'95 C280
There's one screw closest to you using a small screwdriver. You can see it looking at the speaker vent/cover. Use the screwdriver to fork up that same side. On the other side of the vent it's got a tab holding it in place. So one side near the windshield is a tab, the other towards you is the screw. Fork your side up and slide the vent off.
When the vent's off, use a flat head screw driver to loosen up the speaker's edge. Basically pry the speaker out evenly. Pull it up, disconnect the connector and it's a snap from there.
edmu
Feb 7, 2009 01:40 PM
DDAYMEN
Dec 30, 2007 12:53 AM
