84 190D Front Speaker Removal?
I just got some new Infinity speakers to replace the Altec's that were previously put in the dash, but I can't figure out how to do it without disassembling the dash. Anyone know how? Thanks!
Andrew '84 190D '67 250S '69 220D '95 C280 |
There's one screw closest to you using a small screwdriver. You can see it looking at the speaker vent/cover. Use the screwdriver to fork up that same side. On the other side of the vent it's got a tab holding it in place. So one side near the windshield is a tab, the other towards you is the screw. Fork your side up and slide the vent off.
When the vent's off, use a flat head screw driver to loosen up the speaker's edge. Basically pry the speaker out evenly. Pull it up, disconnect the connector and it's a snap from there. |
