Garage Door Remote
Old Oct 1, 2005 | 06:20 PM
EOLJR's Avatar
Default Garage Door Remote
Does anyone know if the garage door remote will operate the "Liftmaster" garage door openers? Mine doesn't seem to work.
Thank, EOLJR
Old Oct 5, 2005 | 08:44 AM
medisnl's Avatar
Default RE: Garage Door Remote
mine works just fine with that brand[sm=burnout.gif]
Old Oct 6, 2005 | 11:16 AM
EOLJR's Avatar
Thanks, I must be doing something wrong with the programing procedure. Will try again.
Old Oct 6, 2005 | 02:00 PM
tookrazyj's Avatar
I have the same brand and cannot get the remote to program. I might try MB.
Old Oct 24, 2005 | 02:57 AM
MBZTech's Avatar
Does your garage door opener have rolling codes?? If it does you have to press a button on the garage door opener to learn the code.
Old Oct 25, 2005 | 11:07 PM
AMPM's Avatar
Garage door rolling code
1.On the inside above the rear-view mirror are 3 buttons,
#1, #2, and #3 (from left to right).
2.(This step will erase existing codes in #1, #2, and #3, so you only need to do this step once.) Hold down #1 and #3 simultaneously for around 20 seconds until light blinks.
3. Hold remote control 2-5 inches from chosen button. Let's say I choose #3.
Put something in the door beam to keep it open.
Press button on remote control AND #3 at the same time until rapid blink.
4. Go to Garage Door controlling box (mine was located in the middle of my garage on the ceiling with the garage light). Press the Learning Button and release.
5. Go back into car and press #3 and then release.
Then press #3 again and release.
That's it!
6. *** DO NOT throw away garage door remote as you may need to do this again sometime in the future.
7. 2nd person is helpful.
8. You may have to try it a couple of times till you get it right.
Old Oct 26, 2005 | 08:04 AM
EOLJR's Avatar
Thanks, AMPM. This information is great. I'm going to try it today. Let you know how I made out.
Old Oct 26, 2005 | 04:19 PM
EOLJR's Avatar
Thanks, AMPM. I just programed the opener like you said with one exception. In step 5 you only have to hold the car button once until the Garage door opener itself flashes indicating that it has received the signal from the car.
Thanks again.
springhillmb
Sep 28, 2007 01:38 PM
KenF
Dec 4, 2005 03:30 AM
sbeemish
Nov 5, 2005 02:44 PM
fay3131
Sep 27, 2005 10:58 AM
riz
Dec 17, 2004 03:19 PM
