Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Mercedes S Class
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
Old 12-17-2003, 10:31 PM
T Lindau T Lindau is offline
Default Engine Vibration at stop
S 320 Inlne 6, for some reason, when in drive or reverse, the car seems to vibrate when stopped.(ex at a stop sign).The enigine runs fine. 700 rpm at idle.500 when in drive. You feel vibration in the seat and steering wheel.(not major)Car has 90k miles and the engine just had amajor tuneup.Car drives great, just a little vib at the stop.Are the engine mounts worn?Thanks T. Register today for free or log in if already registered to remove this ad!
Old 12-25-2003, 01:21 AM
jetforeman jetforeman is offline
The motor mounts for this engine are a common item to fail, I would have them checked along with the transmission mount. If you want to look at the mounts yourself you can pretty much tell if they're bad or not by seeing if they are collapsed. There should be about a 1" gap in height between the lower section of the mount and the the top section that bolts onto the block.
__________________
Dale
<br />
<br />95 E320 - 174k miles and still going strong.
<br />00 C230 SE - 59k miles and still making boost!!
<br />86 Nissan Pickup - 257k miles and still doesn't leak any oil.
Old 02-16-2005, 01:41 AM
siddiqui2000 siddiqui2000 is offline
Default RE: Engine Vibration at stop
Its the motor mounts that need replacement. I had the same problem. Buy cheap OEM parts at http://www.importec.com
__________________
siddiqui2000
Tags
benz, car, class, e, e320, engine, forum, forums, idle, mercedees, mercedes, problem, reverse, stopped, vibration
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
