AC Problem
Old Aug 14, 2010 | 06:53 PM
jrbjrb's Avatar
Default AC Problem
The rear air is okay (although never really cold, around 52 degrees) the front will blow cold air sometimes in am. It’s kinda weird, in the mornings when I leave the house, (its cool out) the front air is okay. When it gets up to mid 80's or so the front quits blowing cold air, the rear is still okay.
The compressor is working fine, no leaks, pressure is good.
Any ideas
thanks
Old Aug 15, 2010 | 10:43 AM
waybomb's Avatar
You say pressures are good. If so, then the climate control must be mixing hot air from the heater side in with the cold air from the ac side.
Old Aug 15, 2010 | 10:17 PM
jrbjrb's Avatar
I unpluged the sun sensor under the hood and it seemed to improve the cold air coming from the front. I was not aware the front sun sensor affects the heat ducts
Does this make any sence ?
4XXXX
Sep 1, 2008 01:52 AM
e320drivemecrazy
Mar 11, 2008 06:02 PM
bluebirdnips
Nov 19, 2007 02:34 PM
rameets
Jun 20, 2007 02:43 AM
legenesepimp
Nov 4, 2005 01:36 PM
