Help removing W211 rear bumper cover
Old Jul 28, 2010 | 10:59 PM
jvieira's Avatar
Post Help removing W211 rear bumper cover
I just purchased my first Mercedes. 2007 E350 4 Matic with the sports package. I am very happy with the purchase.
The rear bumper cover does not line up with the body panel above the driver rear wheel well (less than a 1/4" inch). It bothers the hell out of me everytime I look at the car. I was hoping the remove the bumper cover and adjust so that it lines up correctly.
Can anyone provide detailed instructions?
Thank you.
Old Jul 29, 2010 | 05:18 PM
remove the trunk liners on both sides there are screws I think 10mm on the inside of the quaterpanel where the panel meets the bumper you can probably loosen them a little and might be able to get enough movement to fix it. very easy to remove the whole bumper cover if needed.
Old Jul 29, 2010 | 08:58 PM
jvieira's Avatar
Thank you Chassis221.
Sorry for the newbe question, but are the trunk liners inside the trunk or the liners inside the rear wheel wells?
Old Jul 29, 2010 | 09:17 PM
in the trunk, but also you might have to remove part of the wheel well liners for a few more screws....not totally sure but on some of the older cars there are fasteners at both spots
Old Jul 29, 2010 | 09:30 PM
jvieira's Avatar
Thumbs up
Thank you.
Old Jul 31, 2010 | 08:44 AM
jvieira's Avatar
Talking
I love this forum already! I easily saved a couple hundred dollars by saving myself a trip to the bodyshop.
I spent a couple of hours yesterday carefully taking apart the trunk liner in order to access two 10mm bolts and a third 10mm bolt in the rear wheel well behind an access panel. I was able to re-align the bumber cover quite easily and then tighten the bolts.
Now when I glance at the car my eyes do not target the mis-aligned bumper cover anymore!
Thank you once again Chassis221!
Renaje
Feb 19, 2012 03:39 PM
charIie
Jan 3, 2006 06:33 PM
mwhitsett
Dec 14, 2005 08:18 PM
Armen
Aug 31, 2004 06:23 PM
Armen
Aug 31, 2004 02:42 AM
