C220 CDI no battery no trunk
Old Jul 16, 2010 | 06:18 PM
JTarrafa's Avatar
Default C220 CDI no battery no trunk
Good evening,
I need help with a Mercedes C220 CDI 1998.
Was stopped for a long time and was out of battery due to the death of a family.
Right now nothing works except opening the driver's door with the key manually.
As the battery is in the trunk, I can not open with the manual switch, so you can load to the battery.
Someone tell me what other alternative exists that can put the car to work, or another way to open the trunk.
Thank you.
Joćo Tarrafa
Old Jul 18, 2010 | 05:14 AM
platonmind's Avatar
Another way to put the car to work is to jump start from front. Positive jumper cable connect to the starter`s terminal and negative jumper cable connect to anything metal to the engine.
NAZ's Avatar
NAZ
ok wat u need to do.jack the car up the front,on the left side front towards the passenger front there will be a plastic cover there, remove cover,this is your live point of the car as in battery positive+,fit jump lead positive on,negative should be on body,after fitting the leads oprete key fob the trunk lock will open....
Old Jul 18, 2010 | 12:39 PM
JTarrafa's Avatar
Default Thanks
Thanks. I'll try to do that.
I'll send news.
Regards
Rudy-mbz
Sep 24, 2013 02:30 PM
dee2000
Jul 21, 2011 07:43 PM
cbwhitley
Aug 15, 2007 04:44 PM
silver seattle s5oo
Jan 8, 2007 07:07 PM
C220_white
May 27, 2006 10:30 PM
