99 SL 500 soft top release
Old Jul 5, 2010 | 10:06 PM
CAK's Avatar
CAK
Default 99 SL 500 soft top release
I have a 99 SL 500, last week I was able successfully to hoist the hard top off for the summer, but when I pushed the red button forward to open the soft cover, no noise came out of the back and nothing happened tried that few times and finally had to return the hard cover back on (it worked fine last Summer).
Would there be any fuse that is out, that is locking the soft cover in place? any suggestions/help would be appreciated before the nice weather changes again, Thanks
Old Jul 6, 2010 | 07:19 AM
SunGuy62's Avatar
Stuff I'd try...
Reset windows-in car, engine on, windows up. Push both window buttons simultaneously and hold the switches down even after they stop; count to 5, release. Reverse what you just did and put the windows back up, hold switches down, count to 5.
Try to lower top.
If NG, replace fuses #19 & 20 in the front fusebox...even if they 'look' good
Try top again.
If NG, you probably have DTC's (trouble codes) in the top controller that will have to be deleted. Once deleted, try top again, several times, and re-check controller for codes.
Bob
Max Macson
Apr 20, 2011 09:18 AM
Cobramedic
Jun 9, 2008 01:56 AM
V XII
Jun 9, 2006 09:24 PM
Diane Raabe
Jan 19, 2004 05:38 PM
shawme
Oct 30, 2003 09:41 AM
