Does not drive after changing tire
Old Jun 22, 2010 | 09:26 AM
Jack21's Avatar
Default Does not drive after changing tire
Recently I got flat tire at my drive, so I changed the tire myself and put spare tire. After changing the tire, when I put the car for parking to drive, it does not drive. I feel some kind of brake is on but can't figure it out what it is. Please suggest me what to do.
Jack
Old Jun 22, 2010 | 12:17 PM
depending on your car you might have differnt lugs bolts for the spare tire and if you used the wrong ones your lug bolts are probably grinding against your E brake assembly and are binding up your rear wheels
Old Aug 13, 2010 | 06:13 PM
TireCrawlerNikki's Avatar
I agree with chassis221. There are general shorter bolts for the spare wheel
Old Apr 30, 2012 | 02:09 PM
Diwakar Patel's Avatar
i changed flat tyre of my merc E 200 1999 model it wont move now what can be the problem.....
Old May 4, 2012 | 07:16 PM
raymond~'s Avatar
did you read the above posts? basically what may have occurred is that you used lug bolts
which are too long for the new wheel. the longer bolt reaches too far into the hub and
is jammed against the parking brake mechanism.
IF YOU ATTEMPT to drive off, you risk serious damage to your brakes. STOP.
examine the lug bolt. insert into the new wheel and measure how much it extends out the
back of the wheel. it should be very close to the same measure as when used on the old
wheels. if you measure more, the above mentioned situation is what likely has occurred.
TCES
Aug 21, 2013 09:34 PM
Jopenko1
Dec 10, 2012 03:18 PM
Pholmqvis
Mar 5, 2012 02:15 PM
farid
Mar 29, 2011 06:57 AM
Victor_x
Jul 3, 2009 09:05 AM
