C240 A/C Fan not working
Old May 24, 2010 | 10:37 AM
RStewie's Avatar
Default C240 A/C Fan not working
Just yesterday my fan for my A/C stopped working. I'm pretty sure it's just the fan--it's been making a whistling noise for a little while, and I can turn on the A/C, but it doesn't blow out the vents. It's very cold air, but it's not moving anywhere.
Can my regular mechanic do the work, or is this a "dealership only" type of fix?
If it IS a DIY, does anyone have a step-by-step of the fix?
It's 90 degrees here with 98% humidity, and I'm dying to get this fixed. Thanks for any help!
Old May 24, 2010 | 07:35 PM
ahaus's Avatar
What year, I looked for 2002 c240 and it does seem to complex, 9 tenths of an hour.
Old May 24, 2010 | 10:58 PM
remove passenger dash under panel. should be 3 torx screws, then youlll see the blower motor box. 5 torx screws then the cover comes off then 3 or 4 more torx screws to remove the blower and regulator. easy. just have to spend some time on the floor on your back.
Old May 25, 2010 | 07:39 AM
RStewie's Avatar
Thumbs up Awesome
Thank you! Sounds like a DIY to me then. It's an '03, BTW.
Old May 25, 2010 | 10:21 PM
simons240's Avatar
yup i had the same prob about to days ago, just take of the bottom pass panel and make shure the harness to the blower is not loose, i gave it a good clean and oppened the male contacts to give a it a better contact,
Old Aug 14, 2010 | 11:20 AM
toddbinkley's Avatar
Default C240 202 Squeeky A/C blower.
The blower fan is working properly on all speeds. It just squeaks persistently. Anybody know how to stop this annoyance. Does it need to be replaced? If so can I do it? (Curious and tired of the noise.)
Old Jun 21, 2011 | 08:19 PM
stuntwoody's Avatar
I'm having simlar probelms with my 2001 C240 - A/C & Fan is not working What do I need to do or what can i tell a mechanic friend the problem is?
patricknif
Mar 4, 2012 06:38 AM
Paul Dalton
Feb 7, 2012 02:37 PM
Mr.47
Sep 7, 2007 08:44 PM
lexasgs400
Sep 11, 2006 07:11 PM
mikem9
Jun 10, 2005 10:56 AM
