SL 300 24v
Old Apr 15, 2010 | 09:40 AM
WillFritz's Avatar
Default SL 300 24v
Car has a missfire and is backfiring out of the exhaust even on tick over it is poping i fitted a new distribitor cap and rotary arm and new spark plugs
can anyone help
thanks will
Old Apr 17, 2010 | 02:58 PM
Arildo's Avatar
Have you checked the ignition timing? And if ignition wires is ok?
Old Apr 19, 2010 | 03:09 PM
WillFritz's Avatar
Default hi
Hello Arildo how would i know if the ignition timing is out?and how do u check it if it is?And what would cause it to go out?
Will
Old Jul 8, 2010 | 04:41 PM
Arildo's Avatar
You have to a get a ignition flash light (bougt at an ordinary car chop for about 50usd). and then read the manual book for your car. I bought mine at "www.Haynes.com" from the UK.
Old Jan 6, 2012 | 08:54 PM
Arildo's Avatar
How is it going? Please send a message when its work and what was wrong! (It will improve my knowledge and also help others)
Old Jan 14, 2012 | 03:53 AM
brookings's Avatar
I'd check for vacuum leaks next. How many miles are on the car? Does it backfire and or miss all the time? how's the power and does it still miss on acceleration? It is common for the hoses to get brittle in time and crack, also the seals around the injectors can do the same. Get some in the can aerosol starting fluid or carburetor cleaner or brake wash and spray around the hoses and injectors while running and listen for a change in the running of the engine. there is no point to do anything else until you check for leaks first. don't smoke while spraying fluids. try to keep spray limited to just vacuum hoses, the rubber boot connecting the intake to the air flow meter and the injectors.
babyface
Jun 11, 2011 03:33 PM
lowesmeister
Dec 2, 2007 03:11 PM
lowesmeister
Feb 14, 2007 07:39 AM
SilverSpear
Mar 4, 2006 03:14 PM
ads_wight
Oct 6, 2005 06:56 PM
