95 s420 ASR light
Old Mar 9, 2010 | 03:38 PM
dimka18's Avatar
Default 95 s420 ASR light
hey guys, well today i changed my throttle body(cuz my old one was busted) and when i put it in, the car started perfectly ASR light went off and the throttle worked perfectly, the car ran for about 30 sec( did not push the gas or anything), then there was a little clicking noise and the ASR light come on and throttle didn't work again, turned the car off and started it again ASR light off started up just fine and throttle worked then again 20 seconds later light comes on and throttle don't work, so i took the battery terminal off waited for a few min and put it back on and know everytime i start the car the ASR light is on and throttle dont work. has anyone had this problem? what can it be??
Old Mar 11, 2010 | 08:26 PM
MB-TECH-38's Avatar
your throttle needs to be programed [ abductations need to be set can only be done with MB computer . some things just need to be done at MB shop independent / dealer
Old Mar 13, 2010 | 06:50 PM
NAZ's Avatar
NAZ
you get away at times leave the ignition switch ON for good 10 mins it will set it self if not than u ll NEED STAR DIAG TO RESET....
Old Mar 19, 2010 | 08:49 PM
dimka18's Avatar
hey, i toook the car to my local mechanic and he said that there is no communication with the E-GAS computer. i was wondering what can that mean? can a computer just go out for no reason? is it possible its the wiring?
Old Mar 31, 2010 | 10:28 PM
dimka18's Avatar
hey, im looking for a E-GAS computer. but i cant find the same number as on the computer. if the computer has 2 out of 10 different numbers will it not work?
Old Apr 1, 2010 | 05:31 AM
AL-Tuwaijri's Avatar
since u have the W140 Usually its need to be programmed
Old Apr 2, 2010 | 02:17 AM
dimka18's Avatar
hey, alot of people tell me to program it, but i took the car to this one electrition that works on German cars and he says that there is no signal coming from the E-GAS computer.
Old Apr 2, 2010 | 07:21 AM
so mybe the computer have a problem u better change it or try to see what the problem
Old Apr 3, 2010 | 02:56 AM
dimka18's Avatar
okay, but i want to know if the number will make any difference? i found come computers with all 8 digits the same only 2 are different. and i wanted to know if it will work in my car?
Christylove
Nov 7, 2010 04:37 PM
donnie6636
Jun 3, 2009 03:05 PM
mtoler001
Oct 6, 2008 11:38 PM
John T
Aug 10, 2005 02:50 AM
John T
Jul 26, 2005 07:26 PM
