Can't clear ASR and get few codes
Old Jan 30, 2010 | 04:59 PM
JGHowland's Avatar
Default Can't clear ASR and get few codes
I have a 1992 400E the recently had the ASR light come on, and yes, the car went into LH mode. I took the time to build a binary code reader, and finally received a set of error codes today.
I have the ODB1 plug with only the following plugs populated with a connector: 1-3, 4, 6-8, 17, 30. The fault codes I received were few - No fault on pin 4, the codes 5, 6, & 7 on pin 8, No fault on pin 17, and no code read out on the other pins.
I pulled the wheels and the sensors appear to be normal, and I checked the tires for preopr pressure (no change in sensor after correcting tires). I'm at a loss. Anyone have any ideas? I'm concerned that error code 5 on pin 8 may indicate excessive heat in the control module box (F-23).
Any help would be appreciated as I can't leave the family without transportation. Thanks...
Old Feb 8, 2010 | 05:33 AM
MBraven's Avatar
If you short pin 5 and 1, for a second, the ASR lamp will flash, count the flashes.. that is the code. You can then try to erase it, short pin 5 and one for at least 10 seconds (some says 15 seconds), then it should go out.
Old Aug 5, 2010 | 07:47 PM
JGHowland's Avatar
Default Thanks - built a pulse reader
Thanks for the info. Ended up building a pulse reader from parts for about $20. Found I had to short pins for about 15 seconds to clear the codes.
Cheers
deXtrous
Jun 20, 2013 03:44 AM
ikeman2006
Sep 29, 2009 05:41 PM
Pverduzco
Aug 31, 2009 10:15 PM
fritzibea
Aug 19, 2006 05:17 AM
mrrrkva
Jun 5, 2006 05:20 AM
