C230 Power window reset
Old Nov 17, 2009 | 09:53 AM
jrodimer8p4a's Avatar
Default C230 Power window reset
Can someone please write directions on how to reset the power windows on a 2000 C230. I just replaced the battery and need them. I don't have the manual.
Old Nov 19, 2009 | 03:25 PM
mrcoyote's Avatar
Talking
Yes, it's very easy. It's done on the driver's door where all the switches for the windows are.
Start with the driver's door switch. Turn the key "on" so the window will work, but dont start the car. The trick here is to push the switch ALL THE WAY UP OR DOWN and HOLD IT until the glass is all the way up or all the way down. Let's say the window is all the way down. To reset, pull UPWARDS on the switch all the way and let the window come up. That's it. Do this with the other three switches and you're done. If you just pull lightly on the switch it won't work. You'll feel a tiny "click" when you lift the switch all the way up. That's what you want to do.
Old Nov 20, 2009 | 10:50 AM
Thanks for the info. My switches for the windows are on the console in the middle. Is there a different procedure for them? They don't allow you to pull up on them. I was able to reset the sunroof using that method.
Please advise. My car is a 2000 C230.
Old Nov 20, 2009 | 12:53 PM
mrcoyote's Avatar
Talking
Console or door panel, it shouldn't make any difference....unless your car didn't come with switches that (like my '05) have the "auto up" feature. If your window is all the way down and you work the switch on your console for that window, can the window be made to come all the way up with just a quick pull or push on the switch? If so, then do that but HOLD IT in whatever position you used until the window is all the way up. That should do it. Otherwise, I don't know.
Old Aug 15, 2010 | 09:47 AM
Steven Zabo's Avatar
Default 2002 C230 Kompressor driver's door window switch
I am looking for a driver's door window switch for a 2002 C230 hatch back Mercedes Benz. Dual Switch cluster operates driver and passenger door. This is a 2 door car, not a 4 door. Thanks for your help.
Old Jul 1, 2011 | 12:55 PM
iamlostru's Avatar
Default For many models;
Especially if it seems to go down, maybe upa tad, but never fully:
How to Sync Mercedes Power Windows.
  • Bring down both windows at the same time by holding the switches just before the click that brings them down automatically.
  • How to Sync Mercedes Power Windows.
    • Once both windows are all the way down make both switches click by pressing them all the way down. Hold the position to the count of 3.
    'Note:This lets the ECU learn that that is the end of the window track and it records it in memory.
    • Repeat the procedure closing the windows by holding both switches and making them click once the windows are all the way up.
    • Repeat Procedure with the front windows.
    • Bring Moon Roof all the back and hold then all the way forward and hold.
kurnia.2
Feb 11, 2015 03:43 AM
ifthecar
May 12, 2013 02:07 PM
tastoll
Nov 21, 2010 11:00 AM
Rockerfella174
Apr 20, 2008 09:52 PM
Reena
Sep 18, 2005 06:57 PM
