Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Diesel Discussions
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
Old 10-29-2009, 08:22 PM
dcotejr dcotejr is offline
Red face Need Advice - Glow Plugs for 617
Hello all. My daily driver is a 1981 300SD. It has been running great, but it is not 'behaving' the same upon ignition. As you all know, the glow light usually comes on a few seconds in the 'glow' position, and then the vehicle can fire right up. Within the last few days, the glow light has not been illuminating, but the car firs up anyway. It's still in the 60's and 70's here in Alabama, but it's about to get colder, so I'm assuming I'll need to do something soon. Nothing has been with the glow plugs for the last ten years (had a mechanic replace 2 of the 5).
My question: Should I just bite the bullet and install all new Beru or Bosch GP's? Anyone have a preference between these two?
I am not electrically inclined, so even though I've read about checking out the resistance in each plug, I'm not comfortable with that at this point. Does anyone know where there is a step by step procedure (with pictures!) ? My wife says I'm good at following directions. ;-D
Any input is appreciated!
__________________
Don
_____________________________
1981 300SD - 288K and running strong...
Old 10-29-2009, 09:07 PM
ForcedInduction's Avatar
ForcedInduction ForcedInduction is offline
http://www.dieselgiant.com/glowplugrepair.htm
__________________
www.youtube.com/Turbo617
Old 10-30-2009, 01:24 PM
Thumbs up Thanks
That link helps a lot!
Any suggestions as to preferred glow plug supplier - Bosch or Beru?
__________________
Don
Old 10-30-2009, 09:55 PM
Bosch is what should be used. Autolite and Beru plugs are junk.
__________________
Old 11-01-2009, 01:32 AM
Diesel9112 Diesel9112 is offline
And Monark Glow Plugs.
If you are having a Mechanic do it be sure to ask him if he uses a Glow Plug Ramer to clean out the Carbon Buildup.
The Carbon Buildup allows the heat from the Glow Plugs to be conducted into the Cylinder Head instead of the Pre-combustion chamber. This puts more stress on the Glow Plugs because the Glow Plugs draw more amps when cold and less as they become red not.
When I tested a single Glow Plug (outside of the Engine) with an Automotive Dashboard type Amp Meter I foud it pegged the guage out at 60amps and a second are so later as it got red hot the amperage draw settled down to around 16 amps.
How Necessary To Ream Glowplug Hole?
http://www.peachparts.com/shopforum/....php?p=1320545
http://www.peachparts.com/shopforum/....php?p=1019018
__________________
84 300D, Volvo 244GL Diesel
Old 11-16-2009, 09:17 PM
michaelross michaelross is offline
Thanks for the post diesel. I had a bad glow plug and i need a replacement and info on which one to buy. I believe its more than one plug gone bad.
Tags
300d, 617, advice, benz, bosch, forum, glow, mecedes, mercedes, monark, plugs
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
