brake Caliper
Old Oct 23, 2009 | 12:00 PM
raybenz's Avatar
Question brake Caliper
I just got a 2001 E320 and doing what I always do when I get a used car. I service the brakes. I am going to replace the pads on all wheel and the parking shoe. Anyone knows the torque specifictions on the mounting bolts of the calipers.
Is the front caliper piston a screw type or just like the old ATE calipers that just needs to be push back by a C clamp.
Ray
Old Oct 23, 2009 | 04:21 PM
you can just push them in with a c clamp or large channel locks . not sure of the torque on the caliper bolts. but just snug them up.
Old Oct 29, 2009 | 12:32 AM
Davidb's Avatar
Hey RayBenz,
how hard is it to get the rotors off to turn them, or do you just slap new pads on and call it good? We have the same car and mine are about due...
thanks.
Old Nov 3, 2009 | 01:34 PM
raybenz's Avatar
Default Rotors
If you have itted rotors, it is better to replace than turn them. It cost about $15 per face. So that would be $30. A new rotor will cost about $40 for the rear and about $50 for the front.
If is has rusted in place you need to use a puller to pull the rotors.
Old Nov 3, 2009 | 08:07 PM
ohlord's Avatar
Banned
Default You don't
turn w210 rotors,not enough material to do it. If not smooth and able to dress and remove glaze you replace them.
Brake diy on w210 forum diy section.
I carry cryo rotors and prepped ceramic pads.Anti- corrosion treated, -300f cryo treated for better operation and longer life
justaride
May 23, 2008 01:53 PM
KompressorKrazy
Sep 6, 2007 08:39 PM
BenzoPete
Apr 3, 2007 08:21 PM
vifa84
Dec 13, 2005 01:35 AM
mkrists
Jul 22, 2005 06:46 AM
