2002 C230 Sunroof not closing, grinding
Old Oct 22, 2009 | 01:29 PM
jad568's Avatar
Default 2002 C230 Sunroof not closing, grinding
My daughter’s sunroof started out having trouble closing without some assistance and now it grinds and is very difficult to close even when pushing at the same time. I've seen some similar posts however I have not yet found a good detailed solution for repairing the unit. I assume the track has gotten "sticky" and therefore is requiring additional force on the motor and gears.
Thanks,
-John
Old Nov 9, 2009 | 12:52 PM
sportcoat2001's Avatar
Default sunroof sticking?
did you recently replace the battery or disconnect it? in the owners manual there is a procedure to "reset " the sunroof. I had that similar problem after a bat replacement. hope this helps!
Old Dec 18, 2009 | 10:57 PM
drifter erik's Avatar
hello, i have the same car 2002 c230 kompressor and recently my battery went bad and i had to replace it and ever since then my sunroof doesnt' open. can i have specific instructions on how to reset the sunroof, because i don't have the owners manual and also incase that doesn't work does anyone know which fuse is for the sunroof? thanks again
Old May 9, 2010 | 10:09 PM
jose_echeve's Avatar
i think you hold the botom like for 5 secs or something like that
Old May 9, 2010 | 11:17 PM
gilgorm's Avatar
I have used white lithium grease to lubricate the track once the roof is fully open. As well, put a thin layer on the front wind deflector where the sliding portion pushes it down. As well, use WD40 or a light oil on any of the hinges for the wind deflector. Make sure the track where the roof opens onto the fixed glass is clear of debris as well.
To synchronize the panorama roof: The 2002 manual states the following:
Move the switch in the "close" direction, wait until the sunshades are fully closed. Hold on the switch for approx. 1 second.
Move the switch in the "open" drirection, wait until the sunshades are fully opened. Hold on the switch for approx. 1 second.
Move the switch in the "open" direction, wait until the panorama sliding roof is approx. 4 in (10cm) opened.
Move the switch in the "close" direction, wait until the panorama sliding roof is fully closed and hold the switch for approx 1 second.
As I recall, this procedure syncs both the sunshade and the roof. I personally have held the switch for longer than 1 second.
Good luck.
rorsolits
Dec 6, 2011 09:12 PM
Ed Rouze
Nov 16, 2008 10:43 AM
sneezy247
Nov 18, 2006 12:20 PM
tbichsel
Oct 20, 2005 12:55 PM
widebody
Jul 24, 2005 11:58 PM
