Esp,bas warning
Old Sep 9, 2009 | 03:13 AM
davebhoy's Avatar
Default Esp,bas warning
I have a 2002 c180 komp estate,50,000miles.
Intemitently a warning appears for esp and bas,to visit workshop.brakes feel ok no negative feedback from the pedal.....should i worry
Old Sep 12, 2009 | 02:10 PM
asingreat's Avatar
Default BAS Light
Hi. I had a similar situation on my 2000 C230K, which occured about six years after I purchased it new. Didn't notice anything wrong with the braking system, other than the light coming on intermittently. Turned out to be a problem with the battery, which eventually went dead. Upon replacing with a new battery (and then turning the steering wheel all the way left and then all the way right or vice versa as instructed in the car's owner's manual), the BAS light stayed off for good so far! Hope this helps.
Old Sep 14, 2009 | 07:39 AM
davebhoy's Avatar
Thanks for that,does it matter that the battery was fitted last year ?
Old Sep 15, 2009 | 05:43 PM
crusisredux's Avatar
Default Brake Light Switch
Search through the remainder of the forums. This is also anissue with the ESP (Electronic Stability Program) Switch failing intermittently. I had the same problem on my 2000 c230k and a replacement did the trick. Check the forum post here.
IanSLK
Dec 7, 2011 08:16 PM
mouti2005
Aug 15, 2008 02:15 PM
pigzmickey
Feb 8, 2008 03:00 PM
LABoy
Jan 30, 2008 01:16 AM
the prince
Apr 16, 2005 12:40 PM
