Right Front Turn Signal
Old Jul 9, 2009 | 08:25 PM
Rainman66's Avatar
Default Right Front Turn Signal
My wife's 2002 240C has a problem with the right front turn signal. One day it would work and the next not. Now it does not work at all. I swapped the bulb from the left side and still does not work, so I know its not the bulb. I cleaned the contacts, still no luck. Any ideas?
Doug
Old Jul 10, 2009 | 08:02 PM
mrcoyote's Avatar
Take the bulb back out and turn on the turn signal from the steering wheel area. Then take a 12V tester and touch the contacts with the leads to see if the 12V is flashing at the contacts. That's what I'd do to tell you juice is either getting there or not. If not, as I suspect from what you said, trace the power to the bulb socket back to the turn signal switch where the power comes from. If the left signal works, it's not the flasher either.
Old Jul 20, 2009 | 08:44 PM
aviteck5's Avatar
C classes have problems with turn signals. Go to a dealer and buy a "turn signal modification kit." It shouldn't cost to much. let me know if you need instructions on how to install.
Old Jul 28, 2009 | 07:11 AM
Samosa's Avatar
Default 2001 Turn Signal issues
Hi I have the same problem with my trun signals as well as Haz lights. Sometimes after the 10 - 20 seconds delay it works and sometimes do not work at all. What is this "turn signal modification kit" and how much does it cost? Also how to install this kit? Pls. let me know. Right now I cannot even drive this piece of S^^t.
Old Jul 29, 2009 | 10:15 AM
aviteck5's Avatar
The turn signal modification kit is basically a "DTB" or dear technical bulletin. It solves the problem of the turn signal by using an alternate ground. in the wiring for the turn signal wiring harness. There is one kit for both side and it should cost less than a 100 bucks for both together. What you do is remove the turn signal socket, remove the connector for the headlamp, open the connector and remove the ground wire. I don't have the exact pins numbers in front of me, but you should check power to ground to find out which is which easily. Once you do that, you will see a near by ground point within the wires reach. Use a 10 mm to unscrew that and install your ground wire from the kit, and that's it.
stevec230k
Aug 2, 2009 01:00 AM
brookings
Jan 10, 2008 09:11 PM
dpugh
Dec 22, 2007 12:02 AM
frankmarks07
Jul 10, 2007 12:57 PM
gutago
Jan 18, 2005 11:57 AM
