my slk230 sometimes wont start
Old May 27, 2009 | 03:31 PM
frank r's Avatar
Question my slk230 sometimes wont start
I bought my 1999 slk230 about 6 weeks ago just for weekends.just last weekend after being out for a short run and switched off for about an hour.it wouldnt start.after shifting the gear lever afew times and sitting for about an hour it started.this has happened twice since.
Old Jun 10, 2009 | 01:39 AM
livefreeordie's Avatar
Did you get this problem solved??
Old Jun 11, 2009 | 09:40 AM
frank r's Avatar
no.it has just got worse.i stopped for petrol last sunday and had to push it off the forecourt.it started two hours later.but quit while i was driving home.its back with the dealer now.they think there may be a wire broken somewhere.any suggestions.
Old Jun 11, 2009 | 03:41 PM
Have the dealer look at the CPS, Also remove the K40 relay and look at the solider joints.
Old Jun 17, 2009 | 10:07 AM
frank r's Avatar
I got the car back from the dealer on saturday.the problem was apparently a broken wire between the ignition and salanoid,if that makes sense.she,s going well now anyway.so fingers crossed.Thanks for your advice. Regards. frank r
Old Jun 21, 2009 | 04:50 AM
Not sure what wire your talking about but at least your up and running.
Old Jun 21, 2009 | 06:22 AM
Lynz1957's Avatar
Coming in to this late, but I have the same with our SLK - ignition and everything else is on as normally expected, but no life to crank it over on a fully charged battery. Strangely, the radiator motor comes on when all electrics are on and I don't remember this occuring before the problem started. Where is the K40 relay located? Another thread talks about fuses in the wiring circuit outside the fuse boxes between the ignition barrel and starter, where would this be?
Old Jun 24, 2009 | 06:04 PM
TheRemedy's Avatar
Default K40 fix
I had the same exact problem, intermittent stalling and it could not be duplicated. Yesterday the car would not finally crank with a good battery. I start searching and found this along with your post.
I just did this today and it fixed the problem! As soon as i looked at the solder joint and I said "ah ha" It is a very easy job.
"Bazzle's excellent guide to repairing the soldering on this module at:
http://www.slkworld.com/slk-r170-gen...ay-module.html "
I hope this helps everyone else looking.
walpoleauto
Jan 21, 2011 08:17 PM
widmer
Oct 19, 2007 03:14 PM
tsketteler
Jun 18, 2007 05:41 PM
bookerzisme
Jan 12, 2006 08:43 PM
chfang
Jul 6, 2005 11:32 AM
