2000 SLK Ignition Troubles & Died at Light
Old 05-31-2008, 08:26 PM
millerpim's Avatar
Default 2000 SLK Ignition Troubles & Died at Light
For the past several months, when I turn the key in the ignition to start the car, nothing happens. No noise. No engagement. After 2 or 3 tries, which involve removing the key and reinserting it, it will engage and start. Yesterday, I ended up cranking the key 50 times or more before it finally started. Today, it fired right up, but after driving for 20 minutes and sitting at a light, it suddenly died while in drive. I put it in park and tried to start it. It did not start. After a couple minutes of fidgeting with the key and turning it over and over, it finally started. What could cause this?
Old 06-01-2008, 05:04 AM
brookings's Avatar
Default RE: 2000 SLK Ignition Troubles & Died at Light
I would say it was the ignition switch, except for the dieing while driving. that is puzzling. otherwise I had a similar problem on my sl and turned out to be the switch
Old 06-01-2008, 09:07 PM
maybe fuel / fuel filter.
better check the fault code.
Old 06-06-2008, 05:51 AM
Or CPS and Cps (Crank position sensor and Cam position sensor)
Old 11-27-2008, 11:46 AM
Spoke to millerpim and turned out to be a problem with the K40 Relay Module which her mechanic then replaced.
After doing some searching on the web, I came across Bazzle's excellent guide to repairing the soldering on this module at:
http://www.slkworld.com/slk-r170-gen...ay-module.html
I performed this work about two months ago andmy intermittent problem has not occurred since!
Thanks guys!
ronzara
08-20-2008 11:19 AM
jem
01-28-2006 09:26 PM
jerk
01-30-2004 04:30 PM
lmlougee
01-16-2004 06:34 PM
SeaRay250
12-13-2003 07:51 PM
Quick Reply: 2000 SLK Ignition Troubles & Died at Light
