Flooding at startup
Old Sep 28, 2003 | 10:32 PM
Archiele's Avatar
Default Flooding at startup
<IMG src=smileys/smiley11.gif border="0"></P>
When I try to start my 87 300e (3.0l) the motor strtsfor about 1/2 second and dies. Upon trying to start after that it just cranks away. After the second time trying to start, when I remove the air filter, it is very powerfully gassy. There is good(?) compression, 170lbs each cyl, and the spark is a bluish/ yellow color. The only thing that can be left is timing, or the ign parts all need to be replaced, which parts are on order for. </P>
Is there anything simple that I am overlooking?</P>
Old Oct 8, 2003 | 09:52 AM
1989260E's Avatar
Gotten your 300 running yet? My 260E did the same thing and it turned out to be the fuel pump relay. Actually the relay is a printed circuit board in an enclosure that looks like a large relay. Located on the passenger side of the car under a dust cover against the firewall. Mine ran for a second, then quit. Just turned over after that. Replaced the module (relay) and it's been running fine for over 5 years. Good luck! <img border="0" src=smileys/smiley20.gif border="0">
reveller85
Jun 7, 2010 07:06 PM
sunnyside100
Aug 17, 2008 10:36 PM
dsE320
Jul 3, 2005 11:29 PM
mikemcs
Jan 9, 2004 04:08 AM
