ABS/ESP/BAS/brake lights on always. Any hints?
Old Aug 14, 2007 | 06:58 PM
karolos's Avatar
Default ABS/ESP/BAS/brake lights on always. Any hints?
on my 01 S500,my cruise control does not function obviously. Related to the ABS amber light on and two messages BAS/ESP on the message board. My brake lights are staying on constantly. I commute 200 miles a day like this. NOTE: i replaced the brake light switch on the brake pedal (did not do it).I also replaced all the brake pads, and cleaned the ABS sensors on the rotors. PLEASE ADVICE!!!!!!!!!!
Thank you.
Old Aug 15, 2007 | 06:58 PM
karolos's Avatar
Default RE: ABS/ESP/BAS/brake lights on always. Any hints?
[:@]Never mind guys, i had to take it to the dealership today. aparently my CEL came on, my steering was tight and it got stuck on 3-4 gears when in D. i bet this is going to be $$$$$$$$$$$$$[&o]
Old Aug 5, 2010 | 06:56 PM
ericodigie's Avatar
Default Abs/esp/bas/cruise control
What is a CEL? I am having a similar problem. Can you please tell me what the dealer told you was the problem? Any and all information will be appreciated.
Old Aug 5, 2010 | 07:16 PM
CEL check engine light. usually when you get BAS/ESP ABS its a faulty brake light switch but can also be a steering angle sensor fault. or an rpm sensor at one of the wheels
Old Aug 8, 2010 | 06:06 PM
MB Lover's Avatar
Need Help, All of a sudden got BAS, ESP, ABS Lights turned on. Noticed my back lights not working so I replaced my Brake Light Switch and still same problem. I checked all fuses and can't seem to find the problem. Any advice would be greatly appreciated PLEASE!!
Old Aug 8, 2010 | 06:17 PM
MB Lover's Avatar
Default ABS/ESP/BAS brake lights not working
i replaced my brake light switch and still same problem, any suggestions on what to do next? I still have all the lights on and nothing changed. Thanks
Old Feb 6, 2011 | 05:46 PM
kelson's Avatar
I changed the brake pads, and rotors along with the front wheel bearings and seals on my 01 S500. After i finished the ESP light would come on when i would hit 5mph and it would not let me go any faster. I hit the ESP switch on the dash, and then ABS, AIR MATIC, and BAS warning lights all came on...WHAT HAPPENED!? i dont know what i did in the first place, or even go about fixing it. Maybe resetting the ECU?
Old Feb 13, 2011 | 01:12 AM
atwialt's Avatar
I have the same problem (2000 E320). BAS/ESP lights will come on randomly when I'm using the brake pedel. Sometimes the ABS light also comes on. It's weird because it doesn't happen everyday, and I can't see any difference in performance what so ever. I replaced all the tires today after I noticed they were worn and one front tire was worn unevenly causing an anoying vibration at 50 MPH+. I haven't had the lights come on yet since. But it's only been 24 hours. Keeping my fingers crossed.
Old Nov 15, 2011 | 09:57 AM
mc280kid's Avatar
Default Same problem
Nice to see that someone answered with a diagnostic or answer to help. Did I miss it? I didn't change my brake pads and damged rotors a little. Had a non MB mechanic replace rotors and pads but the ABS lights stay on is there a way to reset it or any helpful hints on what the problem maybe. I'm wondering if and when the light comes on the MB dealership are the only ones who know how to get rid of it? I don't believe anyting is wrong with the sensors it came on to notify me and were supposed to reset it. Thank you
Old Jan 29, 2012 | 06:10 AM
dafydd's Avatar
Default ABS light stay on!
My ABS light won't go out, I've changed my brake pads which where worn right down but the warning light stays on, How do I reset warning light?
mc280kid
Nov 15, 2011 10:11 AM
ar1217
Mar 1, 2011 06:21 AM
e55 ///amg
Feb 20, 2010 02:45 AM
LABoy
Jan 30, 2008 01:16 AM
