Cabin Air filter
Old May 20, 2007 | 10:54 AM
Victormyboy57's Avatar
Default Cabin Air filter
Can someone explain how to replace the cabin air filter on a 97 E-420?
Marcus
Old May 23, 2007 | 11:10 AM
startech's Avatar
Default RE: Cabin Air filter
pull out the glovebox
Old May 23, 2007 | 02:47 PM
raymond~'s Avatar
w210s should be very similar.....below is for my 99 E320
yeah, that can be a bugger to remove. here's why: though all the screws are
removed, there are two fins atop the glove box which prevent it from easily
sliding out. if you tug hard enough, it will. if you just wail back and pull
with abandon, you risk damaging the little piston thingy attached to the right
side of glove box which helps the door open slowly. the chain which attaches
the door to the piston is a plastic lattice thing. (love my knack of tech terms?)
can't help you much with the first yank except to use what I tell my brother,
the PHD method "Pull Hard, Dummy". LOL.
if you hook your fingers beneath the door, you get leverage. but that also
has a way of leveraging the glove box upwards...and camming the aforemen-
tioned 'fins' even firmer. so try to pull straight towards your belly button, not
angled up.
once you get the glove box out (which you will), take a file or Dremel to the
fins. lightly. whereas the angle is normally cut at approx 70º or so, change
it to 45º. from now on, removing the glove box will be a breeze.
seem to recall that only 4 screws hold the box in: two on the sides and two
on the box floor. the latch doesn't, nor do the rubber biscuit door bumpers.
filters: okay, towards the back, you should see a horizontal door, secured by sliding retainer.
slide the retainer off and the door pops out to reveal two filters which you'll need to slide out.
http://www.hastingsfilter.com/products/af1147.pdf
Old Jun 29, 2009 | 05:20 PM
will1546's Avatar
The above worked perfectly. Bought the filters online.
Old Jul 5, 2009 | 09:13 PM
Brian Patterson's Avatar
Cool - appreciate that instruction. Now, there are a paper and activated carbon variety of these filters. Any reasons to use either? I would think the carbon version is more effective... thanks!
Old Jul 6, 2009 | 04:39 PM
will1546's Avatar
I saw the same info. Carbon filters are alot more expensive.
StickyBenz
Feb 1, 2012 06:24 PM
dablk1
Mar 30, 2009 04:10 PM
parasuco
Mar 13, 2009 02:21 PM
Lhaitzss
Mar 5, 2007 10:44 PM
gte811f
Oct 22, 2005 10:17 PM
