s430 weird starting problem!!!!!
Old May 6, 2007 | 10:29 AM
NIGEL PETERS's Avatar
Default s430 weird starting problem!!!!!
hi everyone
i have a 2000' mercedes s430 (w220), i recently been having a starting problem,
when i turn the key the car sound like its going to start but it just keeps trying and it wont start
the problems only happens sometimes, and usually when it happens i have to wait about 10 minute and try to start the car again then it will start.
i noticed that the problem dosent happen when the engine is cool, (like in the morning when im about to drive to work), i think most of the times it happened i had driven the car somewhere and parked for less then 2 hours and tried to start it again.
The car now cuts out whilst driving it, it does eventually start again...
ANY IDEAS?????????
Old May 7, 2007 | 04:16 AM
Default RE: s430 weird starting problem!!!!!
CPS! Crank Position Sensor
Both the No Start and "when warm" symptoms seem to be quite common.
The when warm seems to be linked to the sensor having gone out of resistance range when warm.
Stuart.
Old May 7, 2007 | 08:32 AM
Is that the same as a camshaft position sensor?
if not, is the crank shaft position sensor a dealer part only? and how much are we talking?????
Old May 7, 2007 | 10:08 PM
vovpar's Avatar
camshaft and crankshaft are completely different sensors. Where i live you can get one from dealer for about 160 bucks. Hope this helps!!
Old May 8, 2007 | 04:19 PM
FIXED CPS!!!!!!!!!!!!!!!!!!!YIPEEEEEEEEEEEEEEEEEEEEE!!!
THANKS GUYS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 12, 2007 | 11:58 PM
Rockerfella174's Avatar
Maybe do check with the diagnostic machine before replacing the crank or cam sensor... juz to make sure its the right faulty sensor that youre replacing... or youre gonna waste money to replace both...
Old May 13, 2007 | 12:10 AM
Faulty CPS doesn't always set a code.
Stuart
Old May 28, 2010 | 08:06 PM
BlackCherryS's Avatar
Stuart.
Thanks alot!!!! You were so on point with this diagnosis!!! I had the same problem and yes after taking it to the dealer it was definitely the Crank Position Sensor! And was a very easy fix, could have fixed it myself, the part was not that expensive. It was only 70.00 at an imports auto part store but was more at the dealer for the OEM part, but either way thanks!!! It's fixed!!!!!!
Old Jul 13, 2010 | 02:03 PM
georgerat's Avatar
Default mercedes 430 se starting problems
You said you could have replaced the CPS yourself. Where is it located?
Old Jul 15, 2010 | 04:08 PM
Yes it is an easy fix, very easy for real. It's located just between the rear of the engine and the firewall. Someone has pictures posted of the fix and the exact location of the CPS. I think if you back up a little in this thread you'll find the post with the link attached to it.
