Rear rotors removal. HELP !!!
Old Apr 5, 2007 | 03:09 AM
ioang26's Avatar
Default Rear rotors removal. HELP !!!
I am replacing my rear rotors of my 1996 C280 sport.
I removed the wheel, the caliper, also the hex bolt that holds the rotor and then tried to pull out the rotor and nothing. Any suggestions?
What am I missing here? Is it just stuck and rusted or..?
I did try even to hammer it a few times and nothing , the rotor stays at place.
Please, advise.
Thanks in advance!
Old Apr 5, 2007 | 06:39 AM
Default RE: Rear rotors removal. HELP !!!
try releasing the parking brake.
Old Apr 5, 2007 | 11:56 AM
ioang26's Avatar
I have released the parking brake and still nothing. Any other suggestions I would appreciate .
Old Apr 5, 2007 | 07:21 PM
lotusing's Avatar
I pm'ed you but as I said get a hammer and hit the front of the rotor all around and wack it hard, it is just rusted on.If that doesnt work get a bigger hammer.
Old Apr 6, 2007 | 01:07 AM
ioang26's Avatar
All is good guys! I got it out finally.
I just needed a bigger hammer.A few hard times pounding on the rotor and prying at the same time with the pry bar and it came off.
[IMG]local://upfiles/20552/1B9E410197634D7186993C6F05EB223C.jpg[/IMG]
Old Aug 2, 2010 | 01:04 PM
jduartep's Avatar
Hi guys,
Am new to this forum! i have a question, am trying to remove my rear rotor on my c230 and i tried pounding on it and hammer it but nothing happen? i also tried to loose the star thing for the parking brake shoes and release the parking brake to. Do i just need to hammer harder??
thanks
Old Aug 2, 2010 | 05:23 PM
hit it as hard as you can it will come off
Old Aug 2, 2010 | 07:00 PM
waybomb's Avatar
Get some pb blaster and spray around the hub area. Get some sand paper and sand the hub area to get the rust off. Use a 2 pound hammer. Hit both towards the hub and away.
justaride
Dec 23, 2008 06:25 PM
kandrews12345
May 22, 2007 09:53 PM
seitz729
Nov 28, 2006 03:40 AM
jonesy95
Aug 28, 2006 04:15 PM
Lees300te
Jul 30, 2004 07:39 AM
