1990 300e Fuse Locations?
Old Feb 16, 2007 | 05:04 PM
tygger's Avatar
Default 1990 300e Fuse Locations?
I lost my users manual and need to check some fuses. The only fuse location I found was near the driver's side firewall in the engine compartment. Does anyone know if there are any other locations to check???
Old Feb 17, 2007 | 01:05 PM
boycbronco's Avatar
Default RE: 1990 300e Fuse Locations?
That's the only location I am aware of.
Old Mar 1, 2007 | 12:16 AM
brian576's Avatar
yup, that's the only location, if you need a fuse diagram though I can scan mine and get it to you this weekend
Old Mar 1, 2007 | 12:41 AM
tygger's Avatar
Thanks, but I think I got it figured out.
Old Mar 4, 2007 | 05:16 PM
stahlkrieger's Avatar
Behind the battery covered by a plastic cover is a 10 amp flat fuse on the OVP relay (over voltage protection). Also, closer to the firewall, (behind the fuse box you found) is a cover held by screws...if memory serves there are a couple fuses there too.
Michael
Old Jun 8, 2007 | 08:47 PM
forgetit60's Avatar
Default 400e fuel relay location
Old Jul 17, 2007 | 05:54 PM
hittcontact's Avatar
Hi all
I'm now to MB cars and have E300 diesel.The environment control suddenly stopped working.When I try to turn it on, there is no noise at all. Even the fan does not turn on.
Any ideas....please!!!!!!
Old Sep 27, 2012 | 11:10 AM
Robert Driggers's Avatar
where is tps fuse located
S430
Sep 23, 2008 07:09 AM
TimCollins
Dec 13, 2007 05:39 PM
antfow
Jun 3, 2007 11:50 AM
desperado
Jul 25, 2006 09:16 PM
stahlkrieger
Jul 7, 2006 10:28 PM
