S500 Airmatic Problem
Old Oct 29, 2006 | 04:09 PM
  #21
vovpar's Avatar
Default RE: S500 Airmatic Problem
ORIGINAL: tawfiq
Dear vovpar,
The polarity would be red (+) and brown (-) right?, 12v operation required?
You are correct, Mercedes Always uses Red for(+) and brown for (-)
Old Feb 8, 2007 | 07:51 PM
  #22
S 500's Avatar
I HAVE A 01' S 500 WITH AIRMATIC PROBLEMS THE TWO FRONT STRUCS LEAK RIGHT ON TOP, I KNOW THAT THERE IS A KIT TO FIX THIS CAN ANYONE TELL WHERE TO GET IT? HOW MUCH WILL IT COST?
Old Feb 9, 2007 | 04:41 AM
  #23
vovpar's Avatar
ORIGINAL: S 500
i never experience a problem with struts leaking, but i would recommend checking your local dealer
Old Feb 9, 2007 | 10:33 PM
  #24
banker02's Avatar
Funny you should ask. I took my 2000 S430 in today for regular service (A)and found I had a leak in the front struts. It cost $575 to replace the seals with the "kit". I assume if you can buy it yourself and install it would cost only a couple hundred.
Oh, and yes, I got the good ole "Stop, too low" warning light the day before while coming back from the airport. Apparently the lift motor timed out after running too long and it came dow. After pulling over for a bit, I restarted and went on my way with no issues.
Old Nov 19, 2007 | 12:02 PM
  #25
bobmansel's Avatar
i have same problem, i changed the relay and it worked for 3 days and no its giving a loud mammer sound
Old Nov 26, 2007 | 02:37 PM
  #26
mercmad's Avatar
hi, i had the same problem as well i took to my local dealer diagnosed it and found out the compressor unit was faulty thats why my airmatic had stopped working, had it replaced and everything was fine, its quiet a costly item to replace
Old Dec 3, 2007 | 12:30 AM
  #27
Oddemann's Avatar
Several early versions 99-2002 S class has had problems with the front struts leaking at the top. This in cooperation with a bad compressor relay, makes the compressor burn out. Changing the compressor (AND relay) will not simply solve the problem in many cases. There is a non-return valve also located on top of each strut. Normal operating pressure of the system i 6-9 bars. If the pressure in the struts falls below 4-5 bars the non return valve shuts and prevents the car from goingdown onthe wheels.
So i conclude: if compressor stopped working, and the car falls all the way down onto the wheelsjust over a day or two, you also have a leak in the struts. Falling down on one side only means leak on one side only. Same with falling down on both side. Or your non return valves are not working both sides...
Its normal when leaving the car for a longer period (one week?) that the air leaks out of the struts. This is stated in the WIS.
rgds
Odd
Old Feb 9, 2010 | 06:31 PM
  #28
cact25's Avatar
Default 2006 S350 Airmatic problem
My 2006 S350 Warning msg went off right after I left the MB dealer that repaired a flat tire. The nose is lower. The dealer wants $140 to check the problem, and then will let me know if it is covered under the extended waranty. How much is there to check? A fail safe mechanism should have been designed into the system to prevent the car going any lower than normal ride height. I have a switch to raise the body, although I have never needed to do so.
Originally Posted by sleepwalker
then you got a leak. if both front are down with the same level (+/- 2cm), then the valve/pump must be leaking.
if the other side is a bit higher, then it's a shock absorber air leak.
the raise and lower switch is located in the upper control panel. it's together with rear blinds, anti-towing, etc.
the pump is located on the fron right bumper (concealed). you can listen to it or any hissing sound.
coding is what takes vovpar to dig deeper into his pocket now. it is programming the computer/control unit to recognize installed equipments in the car.
Old Feb 9, 2010 | 06:33 PM
  #29
cact25's Avatar
Is the pump located behind the front bumper on this car as well? Thanks.
Old Jun 2, 2010 | 04:24 PM
  #30
dungtran1969's Avatar
Default how to check airmatic problem
hi,guy...I am about to buy a 2002 S500...people talking alot about the airmatic problem and the cost of it...it would be nice if some one can show me the basic thing to test or check if the airmatic or air suspension still good...I never have a mercedes S class ever but love it...thanks
