Where do I put Hydraulic Fluid
Old 06-01-2004, 11:34 PM
mikeselleck's Avatar
Default Where do I put Hydraulic Fluid
I recently had a Hydraulic fluid leak around my driver-side convertible top locking mechanism on my 1992 500SL. When I tested the top after the installation, it started and then stopped about half way. I was able to get it to complete by starting the car and continuing the process, but it was real slow. Could the Hydraulic fluid be low? And if so, where would I add Hydraulic fluid?
Thanks,
Mike
Old 06-14-2004, 11:57 AM
Default RE: Where do I put Hydraulic Fluid
I have the same problem on my '94 SL320 and need an answer to this question, anyone? Any ideas on cost of getting this problem fixed? One estimate I got was pretty substantial.
Old 06-15-2004, 10:00 AM
Ok, It's under the Spare Tire in the trunk....
Old 06-17-2004, 12:54 PM
4smith's Avatar
Sorry, don't understand the answer.. Is there a tank located under the spare?
also what type of hydraulic fluid do you add?
Old 06-17-2004, 08:09 PM
M/B FLUID ONLY,,,IM WORKING ON A 300 SL RIGHT NOW ITS GOT 7 HYD LOCK CYL. LEAKING[:@]I FIXED THE ONE THAT WAS LEAKING NOW ITS LEAKING EVERYWHERE NOW THAT ,,THAT ONE ISNT LEAKING,,,AFTER 14 YEAR THERE STARTING TO HAVE PROBLEMS WITH THEM,,USALLY THEY LEAK FOR THE DOME LIGHT,,,THIS ON LEAKS OUT THE QUATER PANEL ,,,THE PUMP IS UNDER THE SPARE TAKE OUT THE COVER HAS 3X 10MM PLASTIC NUTS,,THEN YOU WILL SEE IT...DAM THOSE CONV...[&o]
Old 06-18-2004, 03:32 PM
4smith's Avatar
Thanks for the info..it was easy when you know where to look.
Old 06-18-2004, 10:03 PM
sleepwalker's Avatar
it's inside the trunk on the middle area under the spare tire. it's together with the motor and pump.
quantity when full is 0.42 liter.
use only ZH-M. the same oil use in level control system, hydropneumatic suspension, ASD, and 4matic.
Old 11-29-2023, 02:50 AM
Varozvi's Avatar
Cool
yes,under the spare tyre
4smith
06-04-2014 01:20 PM
alwaysadeal4u
02-23-2011 09:22 PM
Lugnut
01-14-2007 12:31 AM
01slk320
10-09-2006 05:05 PM
ramminjammin
06-27-2005 07:49 PM
Quick Reply: Where do I put Hydraulic Fluid
