Where Do I put power steering fluid in this car?
Old Feb 22, 2011 | 08:48 AM
alwaysadeal4u's Avatar
Default Where Do I put power steering fluid in this car?
1999 SL 600 benz..
I can't find it at all.. maybe a picture showing me where it is?
please help.. needs it bad..lol
thanks
Russ
Old Feb 23, 2011 | 09:42 AM
SunGuy62's Avatar
The power steering reservoir is at the right front (as you face the car) of the engine. It will have the drive belt connected to a pulley at the front of the reservoir/pump. If you unscrew the cap of the reservoir/pump, you'll see that it is also a dipstick to tell you the fluid level, speaking of which, since your car is 12 years old, you'll need to confirm what fluid is in the system, i.e., Power Steering Fluid or Brake Fluid which many owners use. AutoZone or any of the parts places can help you determine that. Last, if the fluid is low, it went somewhere via a leak. Most often it's the high pressure hose or fitting that's the culprit; it needs to be repaired.
Old Feb 23, 2011 | 09:22 PM
chassis221's Avatar
its under the star in the front of the engine. where the rad hose is. i think.
mikeselleck
Nov 29, 2023 02:50 AM
JC300SD
Jun 5, 2006 12:23 PM
fly_major_fly
Sep 4, 2005 05:54 PM
pparnail
Dec 14, 2003 11:08 PM
pparnail
Dec 12, 2003 01:11 AM
