95 SL500 stuck convertible top
Old 03-26-2008, 01:22 PM
SLK ROLL OUT's Avatar
Default 95 SL500 stuck convertible top
When I hit the convertible switch to open, the driver side remains locked and won't release?
Is there a manual over ride switch or resetting? I disconnected the battery and no luck?
Anyone please help! Thank you.
Old 03-26-2008, 05:52 PM
SunGuy62's Avatar
Default RE: 95 SL500 stuck convertible top
While there is no manual overide 'switch', there is a manual process outlined very well with pictures in your owners manual...have one?
You'll need the tool from the tool kit that has an open end wrench on one end and a 5mm allen key on the other to manually open the latch...have one?
While you're at it, did you check to see if the hydraulic system is full/up to the mark on the fluid canister?
Bob
Old 11-19-2010, 10:02 PM
marvinb534's Avatar
I just purchased a 95 E320. I put the top down today and when I tried to put it up, It started to make a noise, however, nothing happens and it is stuck. I have no manual. Is there a manual override or a method to get it back up before it rains tomorrow.
Thank you and have a terrific day.
Marvin B. Alfred
96SL500
02-07-2012 04:40 AM
noobiez
08-19-2011 03:09 PM
austin108
07-21-2007 11:44 PM
suz
03-17-2007 12:37 AM
jpsetlif
10-07-2006 11:25 PM
Quick Reply: 95 SL500 stuck convertible top
