97 s420 trans problem, code p0700
hello to all, m.i.l light is on ran the codes p0700 transmission control, and another code reads incorrect gear,p0455 evap leak (large). it was running flawlessly until i came to a traffic light, started slipping and making a whining noise. let it rest for about 10mins started the car drove like 100feet, started slipping again, state police had to give me a push to the service road. had it towed back home. so i started playing around it starts up fine, you can hear the whining noise i can put it in gear and seems fine, i even drove it back and forth in my driveway. i did check the trans fluid ,seems ok, no leaks.also what is the going rate for this kind of repairs?any input on the cause? thank you all fo your help
RE: 97 s420 trans problem, code p0700
Here's a website for you. www.worldautoparts.com. Check it out and find what a good rate is for a transmission. Keep us informed as to your progress. As for the EVAP leak, try tightening the Gas Cap, or replacing it. Run a scan, erase that code and see if it duplicates. If that doesn't do it, then some other things may have to be checked, i.e., vacuum hoses, purge cannister, etc. That's when I run to others more qualified to lend a hand.
jasmix
05-27-2009 11:28 AM
